Random 3D surface
Random 3D surface
I would like to find out what's the easiest way of creating a 3d random surface. By random surface I understand something like a terrain, but I would like to specify the a minimum thickness (depth), a maximum thickness (height) and a rectangular area to create the surface. The "hills" and "valleys" should be generated between these values without any discontinuities.
Is there anything in solidworks that might be able to generate this surface? Is there an add-in that might do this?
Thanks.
Thanks.
RE: Random 3D surface
To import the point-cloud data'
http://solidworks.cad.de/mm_24.htm
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
