Surface Thicken problem?
I have created a spline and revolved it around an axis to create a "cup like surface". Im trying to thicken it to create a solid and i get a rebuild error "Face which failed check".
Any help on this one?
RE: Surface Thicken problem?
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Picture two lines intersecting at a right angle, with a radius of X connecting them. Now offset this whole mess toward the center of the radius a distance of X+1. What happens to the radius? I imagine you have the same condition with your spline. A quick check would be to go into the sketch of your revolved surface and try to offset the spline by the same amount/same direction as your thicken. See anything goofy?
Thanks for the help!
Adam
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Thanks for the help.
Splines are not directly related to Surfacing. Sketches are what you use to create surfaces, just as you do with Solids.
Try making something easy like a 6 sided box in nothing but surfaces. I think that is a basic, function of Surfaces and the understanding of how and what you must do to make a surfaces into solids.
Most people are aware of my Bionicle I made 4 years ago, but its still impressive today. Most of the complex areas especially the mask were done with surfacing. That project was what I chose to learn how to use surfaces. I completed it in about 3 months. I was doing it between calls, but it was also a learning experience. I love using surfaces now... they make complex areas that you can't do in solids so much easier.
Bionicle Image
