39NiCrMo3 Equivalent Steel
I have an Italian print that calls out a material of 39NiCrMo3. Do you know what an equivalent US steel would be for this material? I have seen on the web that some manufacturers will say that AISI9840 is the same but it seems as if this steel isn't commonly used in the US.
The part is a gib that is used on a spindle mounting.
Any help you can provide would be appreciated.
RE: 39NiCrMo3 Equivalent Steel
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
