edit dimension problem
For some reason  I can't do edit a dimension of a part by using a math operator i.e: 36-12
where 36 was original lenth and just add -12 after the value in the dialogue box.
Is this a 2008 bug or a setting I have missed.
SW 2008 SP 1.0
Dell Inc. Precision WorkStation 670
2048 Megabytes Installed Memory
NVIDIA Quadro FX 1400
Windows XP PRO SP 2
RE: edit dimension problem
Thanks for the repilies.
This is the 4rth time installing, the PITA factor is high on this one.
SW 2008 SP 1.0
Windows XP PRO SP 2
What does your VAR have to say about this problem?
cheers
I havent contacted them, talking about instalation problems over the phone is so tedious, especially if the final recomendation is to do a reinstall. That I can and usually will do anyways.
I just finished the new install, with what I believe was ideal conditions. The dimensioning issue is still there, I dont believe that it is an "istallation" issue.
SW 2008 SP 1.0
Windows XP PRO SP 2
After discussing this with our VAR it seems that it may be a probelm with a visula basic DLL, not associated with the SW install. They are looking into it.
SW 2008 SP 1.0
Windows XP PRO SP 2
Your VAR must have read my post in the other thread... big smile
