Sheet Metal Merge
Sheet Metal Merge
Really struggling to make this simple operation work.
Picture a flat L shaped plate. I am adding another Unattached Wall into the corner, a fillet if you like. The reason it is a second feature is because the L shaped flat plate is the result of an unbend command. I want to put a feature in the corner, then rebend it.
I can draw the feature ok, but then I cannot merge it all as one to then bend back into shape!
Can anyone help...the feature seems so straight forward but I can't seem to select the right references or something.
Thanks in advance,
Jon Reynolds
Thanks in advance,
Jon Reynolds
