ASME II part D 2007: what happened to table TE-1
I have the 2007 ASME II part D (metric).
Does anybody know what happened to table TE-1?
Those tables for thermal expansion coefficient of ferrous materials are empty!
Only one table part out of 14 has values printed, all others are ****.
Your help would be appreciated. I am looking for CA6NM mean (B) thermal expansion coefficient (should be on page 748, 13Cr-4Ni steels).
yours truly,
tigny
RE: ASME II part D 2007: what happened to table TE-1
My research reveals the following: Errors were found in the values of Metric Table TE-1. Therefore, the metric values were indicated as TBD (To Be Determined) for the 2004 and later editions.
I found a Section II subcommitte proposal tracking number 04-836 that can be found at the following link:
http://cstools.asme.org/csconnect/CommitteePages.cfm?Committee=N20060000&;ProposalsSearch=yes
Enter the tracking number 04-836 into the advanced search box and you will find the subcommitee proposal.
For the status of this proposal, you will have to contact a Section II commitee member. I believe a revised table has been drafted but not yet approved.
Perhaps others here can provide more details as to when the revised table will be issued/published.
tigny,
What you could do for the meantime is to search what you need in 2007 ASME II Part D (Customary) and then convert the values into METRIC.
Dear Codejackal, dear doct9960,
thank you for your help.
I used the last revision of customary values, multiplied by 1.8
Thanks again,
yours truly,
tigny
