Vport will not plot
Vport will not plot
I have created a drawing in 2008, with a vport and it all looks great on the screen.
Except when I go to plot it, the vport will not plot. Also the title box information/artwork will not plot, but if I untick the "plot paperspace last" box, the paperspace info plots but still no vport info. The plot settings are standard and have no problems with those settings. I guess I have turned on/off some variable for the vport. Any ideas?
I have attached the file
RE: Vport will not plot
the dwg is damaged.
"_recover" and "_audit"
Testet with ADT 2004
Tipp: Move the objects into the positive values.
Lothar
ADT 2004
Recovered it and purge it and reopen my drawing and everything is fine. Thanks again
