Solenoid valve manufacturer
Hi everybody,
for some of our projects in Canada, I need explosion proof solenoid valves, with Manual reset/ Position switches option. I would appreciate if anybody shares his experience with any manufacturer since I'm in trouble to find manufacturer.
Thank you so much
Salar
Thank you so much
Salar
RE: Solenoid valve manufacturer
Try this:
http://w
Lucifer has formerly in a very high degree dominated offshore Northsea platform requirements with theese types.
Will probably be on stock at representative in Norway, Europe, if not elsewhere.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
actually almost every body disappointed me. I'm still waiting for Herion and Parker. Therefore, I would appreciate if you inform me about any other manufacturer if you remembered s.th
Regards and thank you all
Salar
If you do not find your solution from above selection, it might be that you are looking for something that does not readily exists or are not easily commercial available. Above together is a sensible selection of what is available world-wide.
Maybe if you could describe your problem more detailed, something could be suggested either with solenoid valves or other solutions.
