Transient Stress Direct Inegration
I am attempting to analyze a small structure under a g-force acceleration on one axis, to determine the stresses developed in the parts during a sudden collision. I only have the linear package, so no MES.
I have been modeling this structure as a linear Transient Stress Direct Integration, using the translational ground motion load curves that can be applied to the model.
Initially I have the analysis set at 1 step with a step size of only 0.01 seconds, and load curves that reach the desired acceleration at 0.01 seconds.
What I am trying to clarify is if this is the correct analysis type to apply a g-force load.
Thank you in advance for your help.
RE: Transient Stress Direct Inegration
I would suggest that you start by simply running a static analysis using a gravity multiplier along the axis of interest. For instance, if in your load curve, your g-force reaches 3g's and you want it along your global x-axis, run a static analysis with gravity set to the standard and use a multiplier of 3 in the x-axis line of the gravity definition screen.
An alternative is to set gravity to standard, place the gravity vector to 1 in the x direction, and in the load case multipliers, put a 3 under acceleration/gravity.
With any dynamic analysis, you need to have multiple time steps within the analysis, so if your load peaks at 0.01 seconds, you need a time step of probably 0.001 so that you get at least 10 steps in the analysis. I dare say that this won't be enough for quality convergence, but it's a start.
Garland
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
I am in the process of analyzing the case in a static load with the gravity multiplier as you suggested, decreasing the mesh size until the results converge.
Then I plan to compare those results to the results of a Transient Stress Direct Integration with 10 steps, increasing the number of steps until those results converge.
I would imagine that the two scenarios should have similar results.
Again, thank you for your prompt response.
