API View change rebuild and save
I have almost no experience with API code in Sw, so I turn to the infinite wisdom of the members of this forum for what should be a simple question.
How complicated would it be to write some code that would create a macro that puts the current model (part or assembly) into the isometric view, force rebuild it, and save it.
RE: API View change rebuild and save
CODE
Dim swDoc As SldWorks.ModelDoc2
Sub main()
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
If swDoc.GetType = swDocDRAWING Then
MsgBox "This macro does not work in a drawing document."
Exit Sub
End If
swDoc.ShowNamedView2 "*Isometric", -1
swDoc.ViewZoomtofit2
swDoc.ForceRebuild3 True
swDoc.Save3 0, Empty, Empty
Set swDoc = Nothing
Set swApp = Nothing
End Sub
