Dimension symbol library - flag note - two letters SC
Can a symbol of SC with a circle be added?
Dimension symbol library - flag note ie <DIM><CL-S>
Default flags current allow one character or up to two numbers.  I want two alphabetical characters.
Doug
RE: Dimension symbol library - flag note - two letters SC
Thanks for the response.  Editing the gtol file worked great.
It requires an editing the solidworks intallations.  A better solution would work on a new solidworks installation.
Is this message as good as an enhancement request?
"Is this message as good as an enhancement request?"
No. This forum is not (officially) monitored by SolidWorks.
Official ERs should be submitted via the SW Customer Portal.
cheers
An even better enhancement request is to give the use the ability to make the gtol symbols graphically (maybe created from of blocks) instead of having to manually figure it out.  (not to mention the ridiculous fact you have to have solidworks closed when you are editing gtol, so you can't see what you've done unless you open SolidWorks again, then if it needs correction, close it again to edit gtol and then restart it again.)
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
