Using Load-Deflection curve in dynamic model
Hello Everyone,
             I have a simple spring mass system representing a landing gear of an aircraft. The landing gear has a composite tube which absorbs energy on impact in a crash situation. Now, I have the load-deflection characteristics of the landing gear which is a highly nonlinear curve (as shown in attached image). How can I convert this curve into a stiffness equation which can be used in the general equation of motion to find the displacement?
David
RE: Using Load-Deflection curve in dynamic model
First approximation is that is just a constant force opposing motion.
Otherwise, use a time based simulation and a lookup table for the force.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
