Interrupting Time for Recloser
Does anyone know what the interrupting time is for a recloser on a utility distribution system? I'm looking for a generic time like with circuit breakers, rule of thumb is 5 cycles.
Thanks in Advance
wbd
Thanks in Advance
wbd
RE: Interrupting Time for Recloser
dpc
What you have to keep in mind is that reclosers have multiple purposes, and different reponse curves for the first time they detect a fault, and subsequent operations aafter they (reclose). This flexibility is what gives them the ability to keep service on under intermitten fault conditons, and to enable downstream devices to lock out before they do. Sorry to muddy the waters, but these are not dvices with a "one number" characteristic.
This is no different than a circuit breaker. Once a signal is sent from the control to trip the recloser, it will always operate in roughly the same time, regardless of the type of curve on the control.
