15 to 25 chilled water with P(max)=0.15 bar
Hi every body,
we have heat exchanger needs chilled water with the following :
150 L/Hr
15-25 C , Inlet chilled water temperature
0.15 bar, Max inlet pressure
Can we use closed system with this very low allowble pressure? If We can't:
When we use an open system,does the pressure being produced by the pump will be more than 0.15 bar even that ,this pump is pumping to the atmosphere?
150 L/Hr
RE: 15 to 25 chilled water with P(max)=0.15 bar
Our city water circuit (in summer) has high temperature around 30-35 C, I think we should use refrigeration device to get water temperature within the specified range.
About the throttling valve, I think the required valve should have very low flow cofficient depend on the pump discharge pressure. So, Is there a valve with this low Cv.
http://www.bellgossett.com/contract/csetter.htm
Best of luck. -CB
