bimal impulse tester
I am trying to figure out on our BIMAL Impulse tester
how to adjust or figure out what to change. The problem is the Italian machine heats up the oil and on the machine the output is C°. We use a monitor to set the testing and see what data is being recorded. The monitor registors in F°. But F° is about 30 degrees off from the machine after translation. Anyone know what’s going on or who to look for in the yellow pages. Please do not say call the manufacture or distributor. Thanks
RE: bimal impulse tester
sounds like they forgot to add 32 degrees to the conversion
°F =(9/5)°C+32
