Tension in steel plate -Ligament strength
Does anyone have a reference for stress analysing a STEEL plate with a number of relatively large holes closely spaced and in a straight line line perpendicular to the Tension axis?
RE: Tension in steel plate -Ligament strength
ASME VIII Div.1 essentially requires, for the calculation of shell thickness, the allowable stress in tension to be reduced by the efficiency of the ligament = 1 - h.dia/pitch.
The code also provides rules for unequal spacing, holes on diagonal lines and multiple hole rows.
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
