One Baloon is Different
I just received this question from one of my co-workers that I was unable to answer.  If you look at the picture the balloon is larger than the rest and the leader is not connected to the balloon even though the style and size are the same.  Also there appears to be two boxes after the #5 item number that I have no idea where they came from.  Has anyone seen anything like this?
Brian
SW 2006 SP 4.1
RE: One Baloon is Different
Those little boxes are "carriage returns" i.e. the enter button on your keyboard.  The box symbol is an asci keycode believe.  As far as how they got in there, I don't know.  Try deleting them.
Are your other balloons 2 characters, they appear to be.
Worst case, change the balloon text from item number to custom.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Dustin,
I ended up preforming the worst case solution.  Thank you for the information about the "little boxes".  I am sure that piece of information will come in handy in the future.
Brian
Brian
SW 2006 SP 4.1
