SW2007 SP3.1 BOM
SW2007 SP3.1 BOM
SW2007 SP3.1 BOM
I'm battling what I think should be a fairly simple BOM issue. I've created a new ".sldbomtbt" BOM template and added a "REV" column to it. The intent is to identify the rev level of each part in the assembly and have that rev auto update when a change is made. When I add a BOM to an assembly, the new template is placed on the drawing (with the REV column). Problem is - I can't figure out how to get the rev to show up in the BOM. Any ideas (a property link maybe?)?
BTW - All BOM info (and Title Block info for that matter...) is identified in the Configuration Specific tab of the Summary Information box from the Properties option for each model.
Thanks - Dave
RE: SW2007 SP3.1 BOM
Can you link/reference other Config Specific properties (CSP) in a BOM?
Is the property in the BOMs REV column, correctly referencing the CSP?
cheers
