'manufactured using loft'
Can anyone elaborate on what 'manufactured using loft' means?
Thank you.
RE: 'manufactured using loft'
What we used to call a loft was a dimensionless drawing  on Mylar drawn at full scale. The part was considered acceptable if it fitted in the lines drawn.
This may not be what you are after, others may be able to help more.
B.E.
B.E.,
Thank you. That's what I was after.
