Matlab random string
Hi there
I would like to ask if there is any random string generator function in Matlab.
Thanks for your time
RE: Matlab random string
Hey,
I don't believe there is one but it should be a fairly simple function to code. I can make one for you if you want?
David
Dear David
Many thanks for your interest. I would be of course really obliged if you could do that.
Manos
Hey Attached is my RandomString(length) function. As you can see it requires a length as input and then outputs the required result.
If you want to add more letters of characters to the list of what can be generated you are free to (as long as the number of characters doesn't exceed 100 the script will still work).
David
Now that is what I call bad Matlab programming!
Try these functions:
The first one generates a random string where repetitions are allowed. The second one generates a random string where repetitions are not allowed.
CODE
function String = RandomString1(n)
% generates a random string of lower case letters of length n
LetterStore = char(97:122); % string containing all allowable letters (in this case lower case only)
String = LetterStore(ceil(length(LetterStore).*rand(1,n)));
CODE
function String = RandomString2(n)
% n must be less than the number of possible letters
% elements of the returned string are exclusive
Idx = randperm(length(LetterStore));
String = LetterStore(Idx(1:n));
M
Dr Michael F Platten
Thanks MikeyP, :S
All I can say is my function works and I don't know all the builtin functions because I don't use it all that often.
All I can say then IrishDave is you have only scratched the surface of a really neat bit of software.  Many people across the World waste hours trying to out-do each other in squeezing a solution into as few lines as possible (Matlab "golf").  Had this thread been in the Matlab newsgroup your solution would have been mercilessly mocked and MikeyP's would have appeared almost immediately in all sorts of similar forms by the regular golfers there.
Want to learn all the tricks?  Frequent that group as well as this site.  The group's FAQ is good too.
I do like Matlab because it allows me to test things in a simple programming language but my main domain is fluid simulations so using Matlab just doesn't work because of the size of my fields, it quickly just isn't quick enough when compared with C++.
I can understand that my solution wasn't the most Matlabish in style, but it still worked and it's not bad programming, just not using the Matlab functions. :)
David
