Manufacturing Question - Milling Profile
I am trying to use the Manufacturing module to create an output file for our mill. I keep getting the following error.
"No material is defined to cut around islands."
I am using the rough follow operation. Any ideas from anyone?
RE: Manufacturing Question - Milling Profile
Look at the boundry you created is the material side the correct side?
How that helps a little.
Brookey
