A514 Gr. E - Mech. Properties at elevated temp
does anyone know where I can get mechanical properties for A514 Grade E at elevated temperatures (650°F)? Specifically I need the following properties...
Elastic Modulus
Poisson's Ratio
Density
Ultimate Tensile Strength
Yield Tensile Strength
Thermal Expansion Coefficient
Elastic Modulus
Poisson's Ratio
Density
RE: A514 Gr. E - Mech. Properties at elevated temp
This is a tall order. After further review, it would appear ASTM A 514 Grade E comes very close to ASME SA 517 Grade E plate material. Do you have a copy of ASME B&PV Code, Section II, Part D, handy? If you do, you will find the following information based on what I stated above @ 650 deg F for SA 517 Grade E plate;
UTS
YS
Modulus of Elasticity
Thermal Expansion
Poisson's ratio
Density - assume unchanged for steel from ambient temperature
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
