Line resolution display
Is there a way of adjusting line resolution in the display of draft files. Lines of different thicknesses often don't appear different on screen. Also aliasing looks bad. I would like the on screen image closer to printouts and images.
RE: Line resolution display
If you use 'DISPLAY AS PRINTED' the lines will appear to increase in thickness as you zoom in - just like zooming in on a bitmap image.
At higher zooms you will not be able to read any of your drawing.
Are you sure you have your line thicknesses set correctly ?
What graphics card & monitor are you using and at what resolution ?
bc
