How to Hold Pipe from Inside?
Is there a device that can grab a 3" aluminum pipe from the inside? It would be like a chuck that expands to hold it from the inside. The purpose of this is so that we can rotate it and laser etch the outside. Thanks.
RE: How to Hold Pipe from Inside?
http://www.mcmaster.com
Don
Kansas City
Benta.
Mike Halloran
Pembroke Pines, FL, USA
To get you started:
http://www.doubleeusa.com/core_shafts.htm
http://www.convertech.com/shaft-adapters.php
http://ww
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
http://www
Ed Danzer
www.danzcoinc.com
www.dehyds.com
