custom balloon shapes
Is it possible to customise the balloon shapes in solidworks
or to create custom shapes?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: custom balloon shapes
Yes i need to use them for BOM Callouts. Can I do this with blocks?
Chris
SolidWorks 08 0.0/PDMWorks 08
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Chris
AutoCAD 06
ctopher's blog
I don't know of a way to add more balloon shapes to the existing ones. Submit an ER if it is that important to your company.
Chris
AutoCAD 06
ctopher's blog
Sylvia
Yes, you had contributed to FAQ559-1229: How Do I Create Custom Symbols? but not the Square-Circle one. I had forgotten those symbols were already listed in the Add Symbol option.
Its similar to typing in <MOD-DIA> to get the diameter symbol out of the modifying symbol library.
Addt'l examples.....
<SC#P-5> will get the 5. square-circle symbol
<SCL-G> results in the G square-circle symbol
similarly ..
<T#P-3> calls for the triangle flag with the included 3.
After adding any symbol to an annotation, right-click it and choose 'Edit text in window' to see the coding.
Remember...![[idea] idea](https://www.tipmaster.com/images/idea.gif)
"If you don't use your head,
your going to have to use your feet."
Chris
AutoCAD 06
ctopher's blog
It is a symbol, but it will also be linked to the Item No. in a SW Bom. I tried with an Excel Bom and it appears, but then is hidden. Maybe a little equation would make it show up? or update?
Sylvia
