matrix arguments
matrix arguments
I have some trouble in data inputing and outputing to a function in Mathcad programming. Is it ok to use matrix as input and output arguments? Is there any way to define some "global" vairable or matrix in Mathcad? Thanks!
RE: matrix arguments
All variables outside the "program" are available inside the protgram; but variables inside the program are local to the program. A common trick for getting multiple results out of a program function is to just stack them all together in a single array (use augment() or similar functions) and pass that array out as the result of the function.
Bung
Life is non-linear...
