2008 lmgrd Error
2008 lmgrd Error
Has anyone had the "lmgrd.exe" error pop up at Windows start-up (and a loud beep) after installing SW 2008?
I get the error every time. My VAR, SolidWorks and my company don't know how to fix it.
I uninstalled SW and ACAD, then reinstalled (SW first, then ACAD). The error stays. When I search for system errors, it says it has something to do with the SW license.
Everything checks and runs good after the error. Just annoying.
Thanks.
Thanks.
Chris
SolidWorks 08 0.0/PDMWorks 08
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
RE: 2008 lmgrd Error
Good Luck.
It's a step in the right direction, but it didn't fix anything. It found the file, but nothing happened.
I think I may need to do another complete uninstall/reinstall. Thanks.
Chris
AutoCAD 06
ctopher's blog
{windows key}-R and type 'services.msc' to open the service manager. Also you can restart it here yourself, so no restart required to see if it's working.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Searching Eng-Tips forums
Chris
AutoCAD 06
ctopher's blog
Stefan Hamminga
EngIT Solutions
I just noticed.
My VAR sent me the license file, it didn't work. I called them, he said it was a temp file.
He sent me a new one, everything works. BUT, I have SW PRO.
When I look at the license info, it says SW Premium. Maybe an issue there?
Chris
AutoCAD 06
ctopher's blog
Stefan Hamminga
EngIT Solutions
Thanks!
Chris
AutoCAD 06
ctopher's blog
