Emboss a Profile on a Cylinder Surface
Good morning, I have a model with an extruded cylinder and I create a plane and inserted into the plane a line and fully defined it and then I used off set entities to create two lines .005 on both sides of the original line and closed the profile. Then I tried to use wrap to emboss the profile on the surface of the cylinder, but wrap did not like that at all. So is there some ofter way of embossing the profile onto the cylindr surface? Thank you in advance for any assistance rendered.
RE: Emboss a Profile on a Cylinder Surface
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
In order for the offset from surface option to work well you need to place your sketch plane correctly and you might need to trim the excess geometry.
Rob Rodriguez CSWP
SW 2007 SP 2.0
http://screencast.com/t/Dp9iNvno
