convert Catia V4 to V5
hello all;
i want to know how to convert Catia V4 3d data to Catia V data as parametrizing
when i convert it it can't be parametrized
what can i do for converting it with design tree (parametic)
thanks in advance.
thanks in advance.
Murat SEYMEN
RE: convert Catia V4 to V5
V4 Boolean tree -> v5 Spec tree
You would have feature parametric...
but the sketch is to be constrained to make it parametric...
try to get v4 model with sketcher drawn...might be possible to get parametric in v5
The best way is to copy the bodies into the V5Part and to remodel the geometry if it is neccassary.
CEROG
For a better understanding see also htt
Fernando
