welding a cylinder tangent to plane
i want to insert a weld bead into an assembly of two parts. one is a cylinder, the other is a plate. they are mated with a tangent mate. I am having trouble selecting a bead type that will work. We thought to use a flange weld at first but it does not work. Anyone have a method that works?
RE: welding a cylinder tangent to plane
If you really need to show a solid weld bead, you may have to create a sweep, but most times a weld bead hatch in the drawing views is sufficient.
If you really, really need Weld Beads, you will have to cheat and create small flats on the cylinder to simulate edges.
-Dustin
Professional Engineer
Certified SolidWorks Professional
