Cold Weather Perc Test
I was wondering if anyone has any tips on performing a cold weather perc test.  We recently hit near-0 degree temps about a week ago and it has been consistently under freezing since.  MT state DEQ allows two different test procedures, one of which allows the test to be run without a pre-soak period.  The test should take about 1 to 1 1/2 hours to complete maximum.  I will shoot for a day when its over 32 degrees, however, I'm wondering about the potential for frozen ground seeing how I am conducting the test 24 inches below ground.
Any help or comments are appreciated.
RE: Cold Weather Perc Test
We encounter that problem in Alaska also - though we run our tests at a greater depth, usually at least 4 feet deep.  As long as the ground isn't frozen at that depth, and air temps aren't much below freezing, tests can be completed satisfactorily.  To keep water/ground from freezing, the perc hole should be covered after digging it, through test completion (between readings/adding water/etc.).  You could get more elaborate, but a piece of plywood is probably sufficient.
I recommend you use one (or more) of the following for such testing...
Amoozemeter (Compact Constant Head Permeameter)
http://ksatinc.com
Guelph Permeameter
http://www.rickly.com/MI/Permeameter.htm
Double Ring Infiltrometer
http://www.rickly.com/MI/Infiltrometer.htm
...and review the following references:
Frozen Ground Engineering
Orlando B Andersland (2004)
Factors Affecting Measurement of the Near-Saturated Soil Hydraulic Conductivity
Vincenzo Bagarello, Massimo Iovino, and Giuseppa Tusa
Soil Science Society of America Journal, Volume 64 (2000)
http://soil.scijournals.org/cgi/content/abstract/64/4/1203
Hydraulic Conductivity in Frozen Soils
T P Burt and P J Williams
Earth Surface Processes, Volume 1, Issue 4 (1976)
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
http://hhwq.blogspot.com
You might also get more reponses by posting in the "Soil/Groundwater environmental engineering Forum"
