Draft Tool for O-Ring Groove
Hi All-
I searched around the forums for this and I can't seem to find it. I'm trying to create draft for an O-Ring groove (removing material at a 70° angle around a circular groove), but I can't seem to find a way to do it using the draft tool. Am I missing something or can it not be done? I know the answer is probably just to revolve a cut around the circular section, but I was just wondering if it could be done using the draft tool.
Thanks in advance.
V
Mechanical Engineer
"When I am working on a problem, I do not think of beauty, but when I've finished, if the solution is not beautiful, I know it is wrong."
- R. Buckminster Fuller
RE: Draft Tool for O-Ring Groove
Nevermind all. Figured it out.
Thanks to all who anticipated responding. :)
V
Mechanical Engineer
What was the solution?
Honestly, I picked the wrong draft reference to pull from/to! Been a while since I've used the draft tool, I guess.
V
Mechanical Engineer
