vortex breaker
vortex breaker
vortex breaker
how would you calculate whether you need a vortex breaker in a cylindrical water tank
RE: vortex breaker
Whats to calculate?
If you are referring to a nozzle that  is the pump suction line nozzle, then Yes! you need a vortex breaker, period.
End of discussion.
RE: vortex breaker
There is no rule that states you need a vortex breaker in a circular tank.  To use or not to use comes down to an engineering decision based on many variables -  tank size, pump out rate, position of the outlet pipe and its configuration, location of the pump in relation to the outlet, experience with similar installations etc.
RE: vortex breaker
The back of th Goulds Pump Manual has a technical secion which includes calculations to determine weather or not a vortex breaker is required.
Contact your local goulds distributor and ask them to send you a copy. They will likely send it for free.
RE: vortex breaker
Very good khardy,
Star for you;- note also that the Goulds website allows you to download free their technical manual (I did).
cheers,
gr2vessels
