higher temp > 125C bonded insulation
We are looking for an inter layer insulation to use in making a bonded copper conductor.  The limit now is around a 125C rating using PEN materials, based in combination on the hot press temp, adhesive rating, and excellent bonding to copper.
Any suggestions?
Dan T
RE: higher temp > 125C bonded insulation
DuPont's Kapton high temperature polyimide is available in film or tape products. Usually used with a silicone based adhesive at the higher end of the temperature range.
