Intermittent Fillet Welds D14.1
I am trying to understand what the correct practice is for intermittent welds for a non-primary member.
The code in question reads:
"6.5.1 ...Welds shall be made on both sides of the joint for at least 25% of its length."
Does the 25% mean that the total length of the welds on both sides =25%
or
That the amount of weld on one side = 25% and the welds are adjacent to each other along the member.
Thanks for you help.
J
This would also contradict what was stated on thread178-45263: allowable spacing between two ajacent welds
or
J
RE: Intermittent Fillet Welds D14.1
I don't have the referenced Code book, but, I wanted to point out that the thread you referenced is not talking about intermittent welds, it's talking about the proximity of two butt welds.
2.11.2 Maximum Spacing of Intermittent Welds
2.11.2.1 General. Except as may be provided by
2.11.2.2 or 2.11.2.3, the maximum longitudinal spacing
of intermittent welds connecting a plate component to
other components shall not exceed 24 times the thickness
of the thinner plate nor exceed 12 in. [300 mm]. The longitudinal
spacing between intermittent fillet welds connecting
two or more rolled shapes shall not exceed 24 in.
[600 mm].
