fracture toughness Kc of martensitic stainless steel X5CrNi13-4
excuse me if this question has already been asked,
I'm looking for the fracture toughness "Kc" of the martensitic stainless steel X5CrNi13-4 (forged), possibly for several different field types (e.g. "center cracked plate in tension", "single-edge crack in tension", and so on).
Any good sources? Sources where to find data for the Paris law of this material?
Thanks in advance,
Thanks in advance,
RE: fracture toughness Kc of martensitic stainless steel X5CrNi13-4
Why do you need this very specific information? Here are some hits from Google;
ht
SFSA Castings Handbook Supplement 8, High Alloy Data Sheets Corrosion Series.
http://www.sfsa.org/sfsa/pubs/hbk/s8.pdf
Save water Drink Beer
thank you very much for your kind help!
The info is needed in order to determine the critical defect length in a zone of a part subjected to very high stresses, in order to check if the radiographic + ultrasonic controls can detect such kind of defects. On the other side, I have to determine the crack growth speed of a crack having a length equal to the minimum which can be revealed by the tests. The part is subjected to "Class 1" acceptability criteria.
I already googled with no good results, but probably my search-keys were different. The idea of looking for CA6NM is very valuable, thanks!
