Rigidized vs. Flat Beams
Greetings all,
I'm looking for some info regarding weather the stiffness and natural frequency of a beam are improved by rigidizing and if so, why. I've looked all over the net and I'm not having much luck. Thanks for your help.
RE: Rigidized vs. Flat Beams
What is "improving the stiffness and natural frequency of a beam" and what does the weather have to do with it?
M
Dr Michael F Platten
Yes, good clarifiactions requested above.
Stiffening a beam of course generally increases the natural frequencies, unless you are adding a lot of mass in the process.
Sirs:
I was wondering what would happen to a rectangular solid aluminum beam's natural frequency, if it is initially fixed at both ends, then its fixed length is increased (ends still fixed)?  The loadings are the beam itself and a wind load at the thin side and flowing over the longer side, like an air foil placed on sides of a wind tunnel.
DaveG
