how to glue Stainless Steel
I don't if this the right section.
For a custum we make a baseball of stainless Steel. diameter 70mm. We allso cut the ball seam, 0.5 mm SS.
Now the problem!
Because it is a design welding is no option
How can we glue both SS to gehter.
http://www.fybaseball.com/Rawlings_baseball.jpg
We used
Loctite
q-glue
sillicon
To require to which must satisfy the solution.
- it must be stuck
- glue or parts of it cannot be visible
On the seam a light tension sits, the seam have the correct
form (he must slightly on the ball be pressed.
Best regards
Now the problem!
We used
Loctite
q-glue
sillicon
- it must be stuck
Best regards
RE: how to glue Stainless Steel
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
www.plymouth.com
I have upload a picture.
The baseball is masive SS
I'll go with the latter, since it looks like the challenging part - try a 3M acrylic adhesive tape.
The Ball is masive prox. 4pound SS
I only need to glue the ball seam on the masive ball
Maybe resistance spot welding the "seam" strip down would work.
But, it wouldn't it look way cooler to drill holes for the seam "stitches", and then glue wire staples into those holes to simulate the actual seam stitches on a real baseball?
