Cross Section Analysis
I need to analyse a channel cross section using the manning equation to determine the 100 year flood elevation. Is there a free program that I can use to input the channel geometry and then apply different Q values to get the water surface elevation. I am only going to be doing one section so did not know if Hec Ras would be appropriate?
RE: Cross Section Analysis
From the thread "Hydrology Software" (thread162-201630: Hydrology Software) http://www
For stand-alone non-eroding channel hydraulic analysis and design, I suggesting use HLW (Dodson & Associates Channel and Culvert Hydraulics) or ECMDS (North American Green's Erosion Control Materials Design Software). Both are available for the MS Windows operating system. HLW is available as freeware/trialware or by purchase (full version). The only difference between the HLW freeware/trialware and HLW full version that I can tell is printing, but you can copy and paste all analysis results so that's not much of a limitation! Still, HLW is very inexpensive (I think) and Dodson seems to be a good company, so you might wanna purchase it. ECMDS is freeware. Even though it is targeted at analysis of North American Green erosion blankets, you can also use it for other channel liner types (soil, riprap, vegetation). SWMM5 can be used for stand-alone channel hydraulic analysis and design as well, but doesn't directly perform depth-variable roughness analysis (though irregular/overbank channel flow analysis can be undertaken).
For stand-alone eroding channel hydraulic analysis and design, I suggesting use GSTARS2.1 (USBR Quasi-2D Channel Hydraulics and Sediment Transport), BriSTARS (FHWA Quasi-2D Channel Hydraulics and Sediment Transport), CCHE2D (NCCHE 2D Channel Hydraulics and Sediment Transport), or MMS (USGS 2D Channel Hydraulics and Sediment Transport). All are available for the MS Windows operating system. Make sure you use the GSTARS2.1 version as it has a pretty good GUI whereas later versions do not. I wouldn't use BriSTARS outside WMS as the interface is not user-friendly. Both CCHE2D and MMS have GUIs, but I think MMS is the much better GUI.
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
http://hhwq.blogspot.com
For One Cross Section, pencil and paper works well.
good luck
Good luck
