battery engineering
battery engineering
I am looking for someone who is an engineer on battery technology. AGM technology preferably. I have some questions about the gassing or corrosion effect of this technology.
RE: battery engineering
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
BUT, a properly managed AGM will not be gassing externally (lifting the pressure relief vents). Gas recombination in an AGM is fundamental element of its design for a very important reason.. to prevent the electrolyte from drying out, causing early life failure.
If it's operated within it's design parameters, you won't have gassing. To learn more about gas recombination in AGMs read this.. http://w
