allowable high rise building drift
hello
i want to ask about the allowable high rise building drift
if (steel or concrete building)
all of us know the allowable story drift shown in table 12.12-1 (ASCE7-05),but i ask about the drift for the whole building
for example building with height 150 meter
what is the allowable building drift?
we use ACI and UBC
I WISH TO find aswer with refrence in code
many thanks
RE: allowable high rise building drift
Building drift should be as the story drift in seismic.
usually story drift is more critical, if the building pass in it , will pass also in building drift
the case is the same for wind loads.
heard that the empire state building sways about 18 inches = but no references for substantiation
That's crazy....The Empire State building is a steel frame encased in concrete.  This concrete encasement increases the stiffness by almost 4 times.  I would love to see some proof of that.
I would believe that the Empire State Building could sway that much (under high wind loads).  It has FMC for the lateral system (with masonry infill - even though the masonry wasn't designed as part of the lateral system, I am sure it is taking some of the lateral loading and, as a result, reducing drift somewhat) and H/500 drift on a 500' tall building is 12".
Not surprising at all.
I also can easily believe 18" sway on the Empire State Building.
18" over a height of 1250' is H/833. Very stiff. Or, looked at another way that is a average story-to-story drift of only 1/8" per floor. Much, much better than a lot of modern buildings.
