Problem With Contect
I have just started using ABAQUS, and is stuck with the following problem. I am trying to simulate a moving load on a simply supported beam. I have tried to describe as much as I can, let me know if you need something else.
Part+Property
Defined a analytical rigid body part (LoadingPlate) which is a line (0,0)(0.005,0) with a reference point at the mid-point.
Assembly
Defined a Part by the name of BEAM. To summarize the steps of definition - in the sketch plotted 4 points (-0.51,0) (-0.5,0) (0.5,0) (0.51,0). Joined them by lines. Assigned a section (profile+material) to the BEAM.
In the assembly aligned the LoadingPlate reference point to (-0.515,0).
Step
Created a General, Explicit Step.
Interaction
Defined a frictionless interaction property.
Created General Contact (Explicit) interaction for the explicit step.
Include surface pairs - ALL* with self
Rest option left as default.
Load
Simple support on (-0.5,0)(0.5,0) on Beam. Initial velocity of + 1m/s to reference point of rigid body and -6000 N load at reference point in the "2" / Y- direction.
Mesh by parts
Global Seed size of 0.005.
Element Type - Library -> Explicit Element-> beam (B21) A 2-node linear beam in a plane.
Job
Submitted the Job
In the whole analysis have defined two surface one is Bottom of loading plate and other is top of beam.
In the JobName.dat file the error statement occurs after:
*dynamic, explicit
*cload
*contact, op=NEW
*contactinclusions, allexterior
*contactpropertyassignment
*output, field, variable=PRESELECT
*output, history
*nodeoutput, nset=ASSEMBLY_MIDPOINT
*endstep
***Error
*CONTACT INCLUSIONS, ALL EXTERIOR has been used or a blank first surface name was specified under *CONTACT INCLUSIONS or *CONTACT EXCLUSIONS, but the model does not contain any 3D elements from which the contact domain can be constructed.
Can any one help me out with this.
Thanks and Regards
Part+Property
Assembly
Step
Interaction
Load
Mesh by parts
Job
Submitted the Job
*dynamic, explicit
*cload
*contact, op=NEW
*output, history
*endstep
***Error
Thanks and Regards
RE: Problem With Contect
Martin Stokes CEng MIMechE
corus
Corus, what is your suggestion if beam element wont work, should I go into 3-D and use solid element to model a beam, or is there a way out in 2D?
