Help with modeling bathroom exhaust airflow
I am trying to find a resource to help me model the airflow in a vertical bathroom exhaust stack serviced by a rooftop fan, with seven floors, each with two bathrooms. I am assuming that there is an integral that could be used to describe the rate of flow at each floor, but I am having trouble figuring out how to set it up. Does anyone know of any books, etc. that contain this kind of information? Any help would be appreciated.
RE: Help with modeling bathroom exhaust airflow
If you do and are, this is a simple air friction problem.
B.E.
You will need a pitot tube and a grille hood and a copy of SMACNA or similar.
You will then measure velocity as instructed in duct cross-section. Flow (cfm) = V (ft/min) X A (ft squared) whan all the rules are applied.
Better to get a guy who does balancing for a living and he'll measure a duct in about a minute. Use a locking duct-mounted balancing damper.
