modifying the model between two analyses
I need to modify one element between two static steps.
Since EMODIF can be used only with a PREP7 I have to solve the first step, enter prep and modify the element, reenter again SOLU. In this way the results of the first solu are cancelled.
1- How can I impose the time running from 0 to 1 for the first solu and from 1 to 2 for the second solu?
2- I use SSTIF to maintain the structural information between the two solve, but how can I retrieve the results for the first solu?
andrea
 Andrea Mordini, Civil Engineer, Ph.D.
 http://www.andreamordini.com
RE: modifying the model between two analyses
after the first run with ANTYPE,STATIC you can FINIsh and enter /PREP7, then re-enter /SOLU but, instead of doing a SOLVE, first set ANTYPE,RESTART. Then set TIME,2 etc. This will "append" your new calculation to the rst file as a new loadstep.
Actually it is a bit more complicated because in this way the analysis is restarted from the rbd file which is saved at the beginning of the first solve step: this means that the modification of the model is not taken into account.
In any case, I solve the problem as reported below.
Thanks, cbrn, you showed me the right direction!
andrea
/SOLU
ANTYPE, STATIC
RESCONTROL, , NONE   ! the rdb file is not written
EMATWRITE, YES       ! the emat file is written
TIME, 1
SSTIF, ON
OUTRES, ALL, ALL
ALLSEL
SOLVE
SAVE$FINISH
/PREP7
... element modification
ALLSEL$SAVE$FINISH
/SOLU
ANTYPE, STATIC, REST
TIME, 2
SSTIF, ON
OUTRES, ALL, ALL
ALLSEL
SOLVE
SAVE$FINISH
