A350 LF2 - material properties
Hi
I'm looking for the mechanical properties of A 350 LF2.
And what is  important where are this properties written in the ASME Code, for reference?
Thanks for the help.CLaude
RE: A350 LF2 - material properties
Claude47 - you'll find LF2 in ASTM A350. It's a low alloy steel with specific low temperature impact properties.
Oops! I didn't include any data!
C  0.3 max
Mn 0.6-1.35
P  0.35max
S  0.040max
Si 0.15-0.30
Cr 0.30max
Mo 0.12max
Cu 0.40max
Cb  0.02max
V  0.05max
TS   485-655MPa
YS   250MPa
El%  30
Cv   20 or 27J (Class 1 and 2 repectively)
As with all this type of data you should check it against the current issue of the ASTM standard before putting it to use.
Also note that the test temperatures for Class 1 and Class 2 are different.  Class 1 is to be tested at -50 F where Class 2 is 0 F.  Depending on where the material is to be used this can have a significant impact.  No pun intended.
I came across a case a couple of years back where the Class was not specified and the owner recieved Class 2 valve bodies and not Class 1 as was implied but not explicitly stated in the purchase documents.  Needless to say impacts at 0 F are not sufficient for the Alberta Oilsands Projects.
EJL
LF2 is a 0.3%C/1%Mn steel. Properties are:
TS   485-655MPa
YS   250MPa
Elong  22%
RA   30%
Cv at -45.6 deg C  20J (Class 1 material)
Cv at -18 deg C 27J (Class 2 material)
All data should be checked against the relevant issue of ASTM A350.
In the ASME Code, properties are listed in Section II, Part A and Part D (design allowables).
