can structural plt be used instead of cast steel plt
REQMNT NEEDS ASTM A148 Gr 90/60 CAST PLT 25mm THK - CAN EQUIVALENT STRUCTURAL PLT GRADE EN10113 S420/ S460NL1 (OR EQUAL)BE USED INSTEAD? OR WILL CAST PLT HAVE PROPERTIES THE STRUCTURAL GRADE CAN'T EMULATE OR ACHIEVE?
RE: can structural plt be used instead of cast steel plt
