Doctor Veklich technolody of bowlegs and knock-knee correction
Bowlegs or knock-knee correction surgery lasts only 30-40 minutes for both legs. The surgery is bloodless absolutely. There are not any traumatize of blood vessels, nerves and muscles. The spinal anaesthetization is using during the surgery. The patient recover consciousness at once as the surgery is finished.
During 3 weeks after the surgery patient moves using wheelchair. Then he begin to walk with help of crutches and insensibly go on foot.
Ilizarov-Veklich apparatus has much advantages as:
* made from titanium it has high margin of safety
* make good use of rods (there are no thin pins) in apparatus that also gives high margin of safety
* by using rods gives much for cosmetic orthopaedy because the only 3 points of apparatus fixation and after the apparatus removal there are only 3 little imperceptible dots on skin
* the apparatus is smaller and light in weight
* by using semi-ring gives patient comfort and convenience during the whole period of treatment
Ilizarov apparatus in comparison with Ilizarov-Veklich apparatus has some weakness:
* by using pins there are 2 point of fixation for each pin, each pin could traumatize blood vessels and nerves. As many pins using as more probability of blood vessels and nerves traumatize. The most complicated parts of the human body for possible traumatize blood vessels and nerves are hips and shoulders.
* by using pins there are not enough margin of safety in comparison with rods
* by using complete ring gives patient low level of comfort because even lying in the bed is not comfortable.
More information: http://www.doctorveklich.com
