min. edge distance a bolt
for wideflange column pinned base plate (A307 anchor bolt inside) what is the minimum anchor bolt edge distance?
6d or 4d
how about bolt to bolt center to center distance distance?
i'm sure 4d for edge distance a307 bolt ( based on anchor bolt design for petrochemical facilities) but couldnt find it in aci..
also the bolt to bolt per aci is 4d.. my previous company uses 5d.. but i couldnt find this to aci as well..
6d or 4d
RE: min. edge distance a bolt
Brb = 0.75 (0.6).t. 2(e - d - 1/16).Fu
although aci has a lot of formulas per bursting, shear edge, etc..
can anyone tell me the standard practice for bolt to bolt distance for pinned support (inside column)...
this is for those with experience with piperack design..
thanks,
175 mm for W14 and more
150 mm for W12
130 mm for W10
100 mm for W8
