Drill size selection
Hi everyone,
           I want to drill a hole of 0.305" in a wooden panel which is 0.5" thick. What size drill should I use for this? and where can I select the drill size from? sorry for my ignorance.
David
RE: Drill size selection
Well there is no .305 drill. A 'N' drill is .302 and then you have a 5/16, .3125.
Ben Loosli
A metric 7.75mm (.3051) drill bit will get you close.  Of course you could always specify a custom tool.
A good reference for standard sizes would be The Machinery's Handbook, or http://www.mcmaster.com/
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
The 'N' will probably wobble enough to scrape the hole to the size you want.
Mike Halloran
Pembroke Pines, FL, USA
I just realized that I can afford to make the hole slightly bigger, so will go with a standard 5/16 drill.
Thanks everyone,
David
http://www.engineersedge.com/drill_sizes.htm
You should be able to find similar for mm.  I used to use a Zeus book.
Bear in mind what the required tolerance is too.
KENAT, probably the least qualified checker you'll ever meet...
