IGES....opening files
Question:
I created an IGES file from a large Solidworks 2007 assy.  The IGES file is about 243MB's.  My question, I am sending via a CD to a company that has SolidEdge.  Does anyone know if they will have a problem to open it?
RE: IGES....opening files
They should be able to open it. They may have better luck with .STL.
You can send both.
Chris
SolidWorks 08 0.0/PDMWorks 08
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Solidedge?  Try parasolid.  I believe SE is also parasolid kernel.  You will have more reliable results than w/ IGES.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
